Oh no! Assuming the second head gasket (and probably the first too) is installed correctly, yeah there has to be an internal leak inside the engine. It's either a slow leak in the block - that took a short while to get into the oil pan - or a big leak in the head - that started when your fluid level got to that point.
If you don't rotate the engine at all, pulling the cylinder head - again sorry - hopefully you can see if any of the pistons or cylinder walls are wet. Will give an indication of which area to start looking for a crack in the cylinder head or cylinder wall for that piston. If nothing looks wet, then the leak is most likely in the bottom of the block - possibly a cylinder liner to block.
