And Ross' idea comes to fruition. Still needs some adjustments to the mount pieces - need to shorten the front tabs - but now that its done I really like it.
So Adam does this become an option?
The brackets are 1.25x1.25 angle, 3.5 inches long - welded at the same 26.75 inch width as the stock mounts. The 'dress up' of the brackets and speedholes are required on my Goblin. The wing i have mounted is a 48x7 (mis-measured originally) aluminum with splayed end plates.
So the stock brackets are coming off (removing weight from the back of my Goblin
) and I have to modify the brake light brackets anyway. So copy away Goblineers if you like what you see.
