DF Goblin Assembly - Installing the Brake Booster and Master Cylinder
SwerveMonkey
will the early model nuts work with a late model booster?
I'm converting from early model to late model systems and found that the booster and cylinders are incompatible between versions.
changing from the early model booster to late model type also means I will need to source a spacer.
comegetjoe
Dang, I know I have one literally laying around here somewhere.... let me look around.
jirwin
To install the brake booster and master cylinder in your DF Goblin, begin by ensuring the area is clean and disconnecting the battery for safety. Identify the designated mounting area on the chassis by referring to the assembly manual. Position the brake booster in place, align it with the mounting holes, and secure it using the provided bolts, tightening them to the recommended torque specifications. Next, attach the master cylinder to the brake booster by aligning it with the push rod and fastening it with the required bolts. Once the master cylinder is mounted, connect the brake lines to the appropriate ports using line wrenches to avoid damaging the fittings. Carefully route the brake lines toward the wheels, ensuring they are secured and clear of sharp edges or moving parts to prevent wear.
After securing all components, fill the master cylinder reservoir with the recommended brake fluid (usually DOT 3 or DOT 4) and bleed the brake system to remove any air from the lines. This step is crucial to achieving proper brake pressure and functionality. After bleeding, inspect all connections for fluid leaks, then test the brake pedal for firmness and responsiveness. If everything checks out, reconnect the battery. Double-check the installation and perform a final test to ensure the brake system is fully operational and reliable before driving your Goblin. Always consult the DF Goblin manual for model-specific instructions and specifications.
______________________________
https://www.medipakiet.pl/ubezpieczenie-medyczne/
This reads like an AI response. "Consult the DF Goblin manual"? lol. That and your signature's URL are very suspicious. I would not be clicking on that anyone.
Traé
It has responded on a few things, not sure what’s going on or if the new website had some kind of AI intelligence added to it.
jirwin
@Adam @Lonny @Brenda You may want to look at this and ban the guy. There are some suspicious URLs for obvious random AI responses to a few threads now. I was wrong, the links are not the signature, they are meant to look like one. They are different in each of the 3 posts. I opened up the link in a VM in Tor Browser (as not to infect my computer lol) and it just takes you to some foreign language site with what looks like something asking for money. This account needs to be banned before anyone accidentally clicks on it.
Doug Rostad
But , dokend didn't say to wear safety glasses and a mask. Or add,,, californians may be harmed
Brenda
Thanks for reaching out. Adam is taking care of it right now.
