Andrew Barry
YT video shows labeling for body to dash connector and to see video description for links. The PDF in that link shows error, does anyone have those labels? Or a description of what to cut and what to save?
What donor car do you have?
This is my Instrument Panel harness.
Yup I see now. The label pdf would be helpful. But I can look at the pin out sheet off all data.I updated my post... Is this the connector?
I don't think it is incorrect. Just the PDF label sheet they posted in vehicle description doesn't work. So I was hoping someone had it.You need to be more specific about what you believe is an error - connector/pin, circuit name? Note that a few hundred wire harnesses by builders and the DF worked harnesses have been modified using these instructions.
I uploaded the PDFs to the new server so the links in the video description should work again. Sorry for breaking those with the new site!For anyone still looking for these links, they appear to be dead on the video. Most likely due to the website update. I was able to link to them through Google:
TC - https://dfkitcar.com/forum/index.php%3Fattachments/ss-tc-body-to-dash-labels-pdf
SC - https://dfkitcar.com/forum/index.php%3Fattachments/ss-sc-body-to-dash-labels-pdf
Base - https://dfkitcar.com/forum/index.php%3Fattachments/base-body-to-dash-labels-1-pdf
