Download bootloader request
Dominicnicklyn
So, here I am again with no answer to my problems. Figured it was time to ask the big boys.
I have an 06 lsj that is having a weird antitheft issue. I bought HP tuners and all the fun tuning stuff to unlock my ecm and disable VATS.
After making sure i take all the extra precautionary steps to ensure my editing would
go smoothly, I conect to the vehicle and read the tune and unlock the ecm. Tables seem to be stock. So, I get all excited and edit my VATS and try to write the tune.
Then it erases the tune and displays "bootloader request download: timed out". And now hp tuners doesn't even show that the ecm is connected anymore
I grab my 05ss ecm that's laying around and try to connect to it. It connected
So my big brain assumes the original ecm has been tuned before (due to having a catless dp) and I order a new one from flashmasters with my vin and OP matched.
New ecm gets here, I put it on the car, double check all my precautions and grounds, conect via hp tuners, read the tune, and unlock the Vin.
I go to write the new tune with VATS disabled and it DOES THE SAME SH!T AGAIN!!!
Now I bricked my brand new ecm and im getting the same error message as the first time.
Help!!!
jamesm
Do you have any other devices attached to the OBD or CANBUS wires?
Also, HPTuners forum has a number of posts related to bootloader timeouts that were the result of aftermarket radios or interfaces that were wired incorrectly.
Dominicnicklyn
I have absolutely nothing else that would interfere. I redone the harness by following the df instructional videos. The car is acting the same way it was before I stripped the donor down.
I tested the CAN bus system myself and it seems to be working correctly.
I'll see if I can find anything else in the hp forum
