Just came in and fit perfectly.do you have a link to what you bought?
Nice, that’s cheaper than Amazon. I guess bonus I have a second one if it was ever needed.They have that bearing on the DF store for $5.50
Yup. I think everyone has had to open that spot up a little.Installing collapsible steering shaft but when I turn the shaft it interferes with the edge of the opening at about the 10:00 location.
Has anyone had to enlarge the opening?
I just installed mine and it seems fine. Rotates completely without hitting.Installing collapsible steering shaft but when I turn the shaft it interferes with the edge of the opening at about the 10:00 location.
What year is your donor, mine is a 2010, just took another look at it thinking perhaps I might have pushed it down to far but it hits regardless.I just installed mine and it seems fine. Rotates completely without hitting.
07What year is your donor, mine is a 2010, just took another look at it thinking perhaps I might have pushed it down to far but it hits regardless.
You are the first person I have heard that from. Maybe DF moved the hole? Because the earlier frames needed a little trimming of the firewall to prevent the steering shaft U joint from hitting.I just installed mine and it seems fine. Rotates completely without hitting.
I used a die grinderWhat’s the best method of trimming and how much, a 1/4” or so?
