RouteAbel
I have a running and driving Goblin (2010 SS/TC) but I need to clear some codes before I get an inspection. I need the check engine light and ABS lights to go out.
These are the codes I currently have.
I have a set of MAP sensors from ZZPerformance so hopefully those will clear P0107 and U2129.
I wonder if P0571 means I need to have my brake position sensor switch calibrated to the car?
For P0036 - should I replace the oxygen sensor on the exhaust?
Are all the rest expected due to parts we have removed?
Many thanks for any input.
0x544: B0158 (Current, Old, History) | Ambient Air Temporature sensor | ||||
0x544: B2555 (Current, Old, History) | Passenger Compartment Lamp Control Circuit Short | ||||
0x544: B2645 - Ambient Light Sensor Circuit (Current, Old, History) | Ambient Light Sensor Circuit | ||||
0x544: U2108 - CAN Bus Error ABS (Current, Old, History) | Lost Communication With Electronic Brake Control Module | ||||
0x544: U2113 (Current, Old, History) | airbags | ||||
0x544: U2125 (Current, Old, History) | telematic control unit | ||||
0x544: U2129 (Current, Old, History) | |||||
0x544: U2172 (Current, Old, History) | Lost Communications With Digital Radio Receiver | ||||
0x7E8: P0036 - HO2S Heater Control Circuit (Bank 1, Sensor 2) (Pending, Current, Old) | Heater Oxygen Sensor Control (HO2S) Circuit (Bank 1, Sensor 2) | ||||
0x7E8: P0107 - Manifold Absolute Pressure/BARO Sensor Low (Pending, Current, Old) | MAP Sensor | ||||
0x7E8: P0449 - Evaporative Emission System Vent Control Circuit Intermittent (Pending, Current, Old) | Evap vent control | ||||
0x7E8: P0532 - A/C Refrigerant Pressure Sensor A Circuit Low (Pending, Current, Old, History) | A/C refigerant | ||||
0x7E8: P0571 - Brake Switch A Circuit (Pending) | Brake Position Switch | ||||
0x7E8: U0121 - Lost Communication With Anti-Lock Brake System (ABS) Control Module (Pending) | ABS |
