BAR-AIR
HERE IS A QUESTION FOR THE GROUP....
Ideally I would love to run a stand alone electrical system for the engine and then just a simple electrical system for the miscellaneous systems for the car (lights, horn etc...). First is that possible with an Ecotec running a throttle by wire system? There are stand alone systems available but only with throttle by cable. The next question, is if a stand alone system is not able to work is there a way to eliminate both the BCM and the main fuse block. It's aggravating to me to have them in the car when a good portion of each of them is not being used. Ideally I would like to make up a smaller fuse panel that would replace the two. Possible???
