Grayson
Codes:
P0123 - Pedal Position Sensor Circuit High (Throttle Body?)
P0107 - Manifold Absolute Pressure (MAP) Sensor Circuit Low Voltage
P0443 - EVAP Emission (EVAP) Purge Solenoid Valve Control Circuit
P0449 - EVAP Emission (EVAP) Vent Solenoid Valve Control Circuit
P0452 - Fuel Tank Pressure Sensor Circuit Low Voltage
P2229 - Barometric Pressure (BARO) Sensor Circuit High Voltage
Hey everyone, I am having some issues with a bunch of engine codes all of a sudden.
I just replaced my serpentine belt and now all of a sudden I have a bunch of codes and the car won't stay running after it starts and it runs really rich and rough when it does.
I think its the throttle body that is the issue that im having but my OBDII pulled all of the codes above. I think it might be both the throttle body and a ground issue but I want to see if anyone else has had this issue or has an idea on what these codes could indicate.
For the P0449 and P0443 codes I think I removed this from my car so that could explain these codes but could be something else.
I dont know why I have the P0107 or the P2229 codes and what they might mean.
It seems like there is a ground or voltage issue somewhere but it could be something else. If you have any ideas please let me know!
Donor: 2007 SS/SC
Donor: 2007 SS/SC
