Soooo long story short I think I need to add a throw out bearing spacer. Anyone have a loose guide on best way to remove the engine? Trying to do Least as possible ya know since I only put like 300 miles on it since I built it and now ripping it apart
Lower the subframe, with the engine, trans, lower control arms, driveshafts all connected.
You will have to disconnect brake lines, parking brake lines, drain the engine cooling system, disconnect electrical.
One more quick question. How hard should you have to push a caliper piston to get it to move? I am having to use some pretty healthy taps with a 2lb hammer to move it in the caliper. I am having the front passenger brake stick hard. I can pull the caliper off and use a clamp to retract the...
Installs in-between the transmission bell-housing and the throw out bearing so it doesn't have to push out as far to do the same job. Includes 1/4" billet aluminum spacer and (3) replacement bolts.
zzperformance.com
Watch the vid it's pretty good. Basically your tob boot can split and leak.
If you think you have blown out the throw out bearing because you are leaking brake fluid from the transmission/engine split, make sure it's not leaking at the elbow where the line enters the transmission. Mine was leaking there without any sign, and I had mine out twice before I realized where the fluid was coming from.
