Stretch2126
Looks like the trans will start making noises in neutral. Goes away when the clutch pedal is pressed. It still drives great but the noise seems like it’s becoming more consistent. Anybody else have this happen?
I was going to guess throwout bearing, but they're typically noisy with the clutch pressed in, quiet when released. I see from your build log that you recently replaced your clutch/flywheel - any chance one or more of the pressure plate bolts is loosening? Any excessive vibration in neutral while revving engine?Looks like the trans will start making noises in neutral. Goes away when the clutch pedal is pressed. It still drives great but the noise seems like it’s becoming more consistent. Anybody else have this happen?
FWIW - The guy who posted the video replied to some comments that it was the "Incorrect preload on final drive bearings"I suppose it could be the clutch but DS’s video is almost exactly like mine it seems like. I can clutch in and out sometimes and it’ll go away but it comes back. I would hope the clutch isn’t already backing off after only having it on for a couple months. I’m putting some fresher oil in the case to see if it does anything. Not metal in the gear oil.
Yeah I saw a couple other videos saying input shafts giving out or another internal matter. It might be time for an f23.FWIW - The guy who posted the video replied to some comments that it was the "Incorrect preload on final drive bearings"
I'm certainly no transmission expert, but I've read that the GM transmissions are usually numerically designated in newton metres, so the F35 is rated at 350 Nm, the F23, at 230 Nm, F40 at 400 Nm and so on. Seems like the F23 would be a step backward if you're overpowering your F35?Yeah I saw a couple other videos saying input shafts giving out or another internal matter. It might be time for an f23.
Well thats good to knowAre you sure it not just clutch noises? Does the noise change if the clutch is engaged or disengaged? Some performance clutches make noises, the F40 clutch makes noises no matter what - performance or stock.
Agree @comegetjoe this is good to know, as I was not aware this was the case. @Desert Sasqwatch It’s a Clutch Masters FX500. I suppose this could be it…never actually thought about the clutch. My question though is: if this is indeed the case, what is hitting what??Are you sure it not just clutch noises? Does the noise change if the clutch is engaged or disengaged? Some performance clutches make noises, the F40 clutch makes noises no matter what - performance or stock.
This is potentially music to my ears. I also have a ZZP aluminum flywheel. Would you mind taking a listen to the videos here to see if your diagnosis applies?I have an FX400 and an aluminum flywheel so it’s chattery when not under a lot of load. But in neutral I do hear the bearing. It changes if I hit the clutch a couple times.
If you hear noise when you Coast or have very little power being pushed through it the gears will make noise. Especially if you have a light flywheel
That is a lot louder than mine. I don’t know if the idle makes it worse, but that sounds like somewhere in the housing might be loose. If you didn’t have trans problems before you probably don’t have them after a swap. Does the sound go away when you hit the clutch? That’ll tell you give you a little more info.This is potentially music to my ears. I also have a ZZP aluminum flywheel. Would you mind taking a listen to the videos here to see if your diagnosis applies?
Videos 6290 and 6316 have the best audio of the noise in question.Rough Idle Issue - Google Drive
drive.google.com
