Can the Factory LSD From the F35 be installed in the F23?
I am reading that the F23 is much stronger. I have the F35 with the LSD. If I can order the F23 from DF, I think it might be worth the $500, but I don't want to lose the LSD...
This is just my engineering opinion:
The design of the GM transmission designations is an indicator of the relative strength - rated in Newton Meters.
The F23 is 230Nm or 170Ft.lb.
The F35 is 350Nm or 260Ft.lb.
The F40 is 400Nm or 300Ft.lb.
Also keep in mind these ratings are based on the relative size vehicle they were designed to be installed in: the F23 in subcompact to compacts (@3000lbs), the F35 in compacts to midsized (@3500lbs.), and F40 in midsized to lower end full size cars (@4000lbs.) - which are incrementally heavier which in turn makes the torque rating also incrementally larger when installed into the same weight vehicle (like Goblin).
In a rough estimatation, based on my flawed thinking, a Goblin weighs 1800lbs. (estimate with driver) or 60% the weight of a subcompact/compact - or 52% the weight of a compact/midsize - or 45% the weight of a midsize/full size. Using these estimates I come up with the following Goblin torque numbers that align with the design factors advertised for the GM transmissions:
F23 - 170Ft.lb. X 40% = 240Ft.lb.
F35 - 260Ft.lb. X 48% = 385Ft.lb.
F40 - 300Ft.lb. X 55% = 465Ft.lb.
Obviously the real world numbers for the GM transmissions, based on the experiences of many Goblin drivers and other Ecotec built vehicles, indicates these numbers are very conservative. But the GM design numbers can also be thought of as a value to base the expected longevity of each transmission installed on an identically built Ecotec. Yes, the transmission can handle the torque, but will it last 5000 miles, 20,000 miles, 100,000 miles?
There are so many factors that play nto this equation that you should probably base your decision on what your budgeted for.
