First step in ducting outside air into the footwell.
Got my interest.... Gonna have to go looking for photos.The Lego goblin had NACA ducts in the side panels with vents on them that could be opened or closed. Not sure how well they worked, but it looked like it would allow some sort into the footwell area.
What did you order for the closable vents for the end of the NACA ducts?Everything’s already been done, lol. Exact parts sitting on my table ready for install. Thanks for finding it!
That is the exact route I have been looking into. We just pulled the hood back off and added insulation on the footwell cover. It has for sure helped with the heat from the radiator coming in the gap between the hood and the cover. Also got the engine covers on today and that helped some more. Still getting heat from the engine bay into the cabin from the gap below the covers and the chassis between the seats. Gonna try to block that with some plexi and then the naca ducts on the side panel should give good airflow.I changed my mind after thinking about this a little further. I'm gonna do the route from the side metal, using a NACA duct with a vent on the end to adjust.
We built a composite aircraft, and used these same vents. On takeoff roll, it would blow your hat into the backseat if they were open, but they also took 200 mph without failing (when they were closed), so they should do fine at these lower speeds. I'll post up when i get the stuff to do it.
I get around it but it’s a bit too bulky there. I figure a slightly smaller one will go in the next gap to the rear and be taller up. More directing air across the front of the seats…. Probably won’t do any good until the front is buttoned up a bit better though.I’m worried about the clearance aroun the clutch also. Not sure how I’m going to handle it.
Looks like those would be great for blocking air, but not flowing air into the cabin... the double bend to fold forward makes it a better scoop i'd think on the slingshot ones.Would these work? Meant for a Cobra and have a hinge mount. Might be able to adapt them to a rollbar mount?
Wind Wings for Shelby Cobra - Forte's Parts Connection
Cobra Replica Wind wings 8 and 1/8 bolt spacingfortesparts.com
