PaulPerger
What are the dimensions of the Goblin's Fuel Tank?
So, basically, 33 inches long by 7.5 inches wide using the smallest measurements... That works for me. THANKS!!
There have been some reports on here of fuel starvation during hard cornering, even with the intake baffle. There is a fairly long string on possible fixes somewhere on here.IIRC, there is some baffling in bottom of the tank.
I looked at the Hydromats quite extensively, but couldn't figure out a good way to get it connected to the stock LNF fuel pump, or put a compatible fuel pump in the stock LNF housing. There also isn't a good size of Hydromat to cover the tank (although its not critical for full coverage). I ended up with an Apex pump with siphon jet. The Supercharged fuel pumps may have a better solution.
I like the Apex system as well, but this is a much less expensive option. I'll make my final decision after I pull the fuel cell and see the pump. My donor is an '06 LSJ so maybe it will be a simpler fit, or maybe I'll look at other options. Still in the planning stages, but I am very impressed with the Hydromat if I can connect it to the existing fuel pump it is definitely the way I'll go...I looked at the Hydromats quite extensively, but couldn't figure out a good way to get it connected to the stock LNF fuel pump, or put a compatible fuel pump in the stock LNF housing. There also isn't a good size of Hydromat to cover the tank (although its not critical for full coverage). I ended up with an Apex pump with siphon jet. The Supercharged fuel pumps may have a better solution.
100% agree. If you can get it hooked to the existing pump, that is the solution.I like the Apex system as well, but this is a much less expensive option. I'll make my final decision after I pull the fuel cell and see the pump. My donor is an '06 LSJ so maybe it will be a simpler fit, or maybe I'll look at other options. Still in the planning stages, but I am very impressed with the Hydromat if I can connect it to the existing fuel pump it is definitely the way I'll go...
Yes, by almost 2".I believe the tank may be a bit wider at the bottom than the top. I recall the angle of the firewall side following that angle getting wider at the bottom.
