New connector arrived and installed. Speedometer is functioning again, along with mileage going up on the odometer. Lesson learned, check the DTC's as they could potentially point you to right direction. It was good that I pulled the harness back in the cabin area as I found more of those awful solder connectors but that could have waited until winter again. After removing the old connector it was obvious where the break was. The purple wire leading into the connector had broken and was only held on by the sheathing around the wire.
