At the same autoX where I bent my lower control arm brackets, I had a buzz start. It is coming from the BCM.
Other than the suspension failure, I am not aware of any electrical failures.
I have not found any loose wires.
Only thing unhooked presently is the horns. I hooked them back up temporarily and that did not stop the buzz.
I tested the horns directly to the battery, and they are functioning and not shorted.
Any ideas what is causing the buzz?
I do not recall if this is the same buzzer the Cobalt used for something like an open door?
I have not opened the BCM yet.
Last resort may just be disconnecting the buzzer if the cause is not found. Not finding the root cause for something like this does not bother me too much. Some of you may be shaking your head a little at me for considering that.
