I have a 2008 TC harness and there is a thicker gray, thicker red with white stripe, and thinner green wire coming from the dash harness near the ignition, anyone know where these come from or go?
Pin | Wire | Circuit | Function |
1 | 0.35 RD/WH | 1540 | Battery Positive Voltage |
2 | 0.35 BN | 4 | Accessory Voltage Signal |
3 | 0.35 BK/WH | 1051 | Ground |
4 | 0.35 D-GN | 5060 | Low Speed GMLAN Serial Data |
5 | — | — | Not Used |
Idk I have the data wires all connected so I’m just stumped at this point.Pretty sure those wires have nothing to do with ABS. I don't recall what they are, since I did my harness almost 4 years ago now, but I believe they are addressed in the wiring videos.
No throttle body movement means no data flow to the ECM. Trace your data wires (tan and tan/black twisted pair) from the OBDII port all the way back to the ECM, check continuity. Note, they change to brown for one step of the way, for some reason.
It looks grey idk man I just can’t believe I can’t the thing to fire just stumped at this pointTheft Deterrent Control Module (GM name) is a 5 pin connector with 4 wires:
Pin Wire Circuit Function 1 0.35 RD/WH 1540 Battery Positive Voltage 2 0.35 BN 4 Accessory Voltage Signal 3 0.35 BK/WH 1051 Ground 4 0.35 D-GN 5060 Low Speed GMLAN Serial Data 5 — — Not Used
Two wire colors match up, but not the grey. Grey is used for the cruise control wiring, and dash illumination, but those would be smaller wires. That's not a brown wire is it?
Idk it looks grey to me it’s looks too light to be brown. Idk what else to check at this point I’ll take all the wiring off and inspect it and see I can figure something out outside of that just confused on if I did something wrong, all good I’m sure I’ll eventually figure it out or I guess I’ll have to get another harness thanks for your help everyone.So if it's brown....
One of the CAN wires is 0.5 brown (odd the rest are TN and TN/BK). And is at the power steering module, so in the ball park. If that's it, could explain the no start, as the network is incomplete.
Yeah I’m just taking all the wires apart again it’s too hard to see with them on there and connected let you know what I can find, thanks for your helpA wire should have to ends. Trace them back either visually, with continuity tester or using a tone generator to test them. Once you find where they pin out, you can figure out what they do.
