So i'm having this problem where if my headlights are on, and I either use a blinker or turn on high beams I will get "engine power reduced" and throttle will be dead. Restart the car and everything works until one of those things happen again.
If I turn the headlights off, I can do everything fine, blinkers, high beams. I have unplugging one headlight, same problem. Both headlights and instantly engine power reduced without doing anything (assuming this is safety in case you dont have headlights).
Code that pops up is x7E8: P2138 - Throttle/Pedal Position Sensor/Switch D/E Voltage Correlation (SES, Pending, Current, Old, History)......which only makes things more confusing.
When this all started I assumed TPS/PPS was the problem, new pedal, new throttle body.
I am using those larger LED headlights that multiple here are using, they all seem to be functioning fine. I'm lost at this point....
Only other thing I have noticed is that with the lights on....left turn signal nothing changes....right turn signal the engine RPM increases very slightly with the turn signal....Any thoughts to at least help me move in the right direction would be amazing.
Thanks!!
Thanks!!
