This. I had a leak on one of my elbows and it was due to not enough tape.Depending on how.tight the fittings are and how thick the tape is, you sometimes need to add 4-5 layers or more.
Depends on how thick your tape is. If the cheapest thing you can find, there is a decent chance that it isn't enough. Of course I'm usually dealing with higher pressures than the heat exchanger loop.Oh wow! I'm really starting to wonder if my two loops of Teflon were enough.
I haven't yet. I just have it bolted into place, most likely will go back and do a thicker Teflon application just to be safe.Depends on how thick your tape is. If the cheapest thing you can find, there is a decent chance that it isn't enough. Of course I'm usually dealing with higher pressures than the heat exchanger loop.
If you haven't already added the liquid, I would probably recommend redoing it. But it might work.
I considered painting my HX unit black as the blue clashes with out color scheme. In the end, I didn't as it won't be seen very much in it's current hiding spot. Maybe in the future I'll change it if it goes to a side of the rear mount spot.This was missing from my delivery last week so just got it today, seems to pretty to install hidden in front under the hood. Any one install it somewhere where else?
I like that! A scoop or a side pod would be pretty BA.Permanently temporarily installed with zip ties, been there over a year. I am working on a 3d printed mount and duct combo piece, but it's not been a high priority for me lately.
