I thought I would start a thread on helpful part numbers others may need, but too difficult to search. If you add to this, please add what doner you have or have it in your signature, so others know what they are looking at.
06 cobalt SS SC
LSJ 2.0 supercharged
MU3 Saab 5 speed
G85 limited slip
Oil filter acd PF458G
FF wix 33980
Spark plugs acd 41-106
Belt gates DK060702
Wheels
update
Forgestar F14 semi concave, matte black 17x9, backspace #10
Old-Vertex RTX 17x7.5 5-110 32p C65.1 satin black
34042809
Tires
update
Toyo R888r
front 245/40zr17
rear 275/40zr17
Old-245/40ZR17 BFG Gforce comp2 as
Seats
NRG innovations RSC-208L/R
Planted technology cobalt seat brackets
SB225DR and PA
with the cobalt brackets, these were a direct bolt in.
Belts
NRG 5 pt harness SBH-B6PCBK
Steering wheel
NRG short steering wheel hub SRK-177H
NRG quick release SRK-650BK
NRG wheel RST-024MB-R-Y
Part numbers ——-
Fuel tank Vent Rollover valve summit TNK-VVR
MOOG camber kit K90473
MOOG outer tie rods rear ES800030
Moog control arms RK620897 and 98
Duralast inner tie rod rear ES80445
Outer Tie rods ft 613.44063
Grom tail light Honda HOE2QMK-X001-Y001 (specific to mine)
Grom tail light blaster 14GROM_REV0A_PI2_SL (specific to mine)
Turn signal switch acd D6254E
Lumen headlights N218X-2-SP and CM
Mirrors cbr1000 HTTMT-MT324 black smoke
Steering shaft GM 15800140
Valve cover gaskets felpro VS50772R
Chain Tensioner ACD 12608580
Post cat o2 acd 25775833
Pre cat o2 denso 234-4066
ACD 213-968 or 12568234 Ho2s
Timing guide bolt dorman 917-954
Supercharger bypass solenoid ACD 1997244, STD U44001
Spal 12” puller fan main rad SPA30101522
Spal 7.5 pusher fan ic rad SPU-IX-30100393
Black diamond grip tape- used on floor
Exhaust collector gasket fel pro 61559
Park brake cable L or R 15875458
Raybestos pads EHT956H EHT1095H
Coolant hose Goodyear 63936- reservoir to engine ‘98 chevrolet truck part
Dayco rad hoses E72461 E72461
IC water pump acd 22718756 Or Bosch 392 022 002
Scotch vinyl mastic pads 2200- sticky back insulated “tape” to protect parts From sharp edges.
Brakes from DF
Ft is 09 base cobalt ft
Rear 09 solstice rear
I’ll edit as I get more
06 cobalt SS SC
MU3 Saab 5 speed
G85 limited slip
FF wix 33980
Belt gates DK060702
Wheels
update
34042809
Tires
update
Toyo R888r
front 245/40zr17
rear 275/40zr17
Seats
SB225DR and PA
Belts
Steering wheel
Part numbers ——-
Brakes from DF
