Background: Everything on the car has been working fine. Engine runs well. All the button panel and dash working properly. The car is almost runnable except waiting for the tunnel cap and new shifter from DF. Had sent the fuse box to Lonnie a couple of weeks ago for a burned circuit board connection which prevented the fuel pump from functioning. He is amazing and wired the circuit board in the fuse box to correct the problem.
Problem: Hooked up the rear tail lights and side mirror turn signals yesterday according to what I found on the forum here and the engine began running rough - misfiring. The accelerator pedal would not function (ie. pushing the accelerator did nothing). Got a code (attached) which said: "P2138 $07E8 -- Throttle/Pedal Position Sensor/Switch D/E Voltage Correlation."
I unhooked all the light connections and restarted the engine. Ran fine. Deleted the above code. Ran another scan. No codes. I did order some resistors from Amazon (not delivered yet) just in case anyone advises me to place them somewhere. When it comes to electricity I just follow the directions - am clueless otherwise.
I'd like to get the car running so I can track it. Am willing to take it back to DF (10 hours away) to see if they can fix it. Can anyone help me to prevent that?
