SeanH
im currently in the process of tuning the car and during logging ill get one good pull (pulls like a rocket 23 psi) then only get maybe 5 psi and under powered. these are my current codes. my brake light is on. cruise control does not work. parking brake is grounded. i have a 25w 100ohm resistor wired in for the CMHSL which shows 8.5 volts without brake applied. all lights work. would any of the codes below put in limp ?
B3903 (current, old, history) stop lamp relay circuit BCM
can i disable these in hptuners?
U2113 (current, history) lost communication sensing diagnostic module SDM BCM aig bag?
U2125 (current, history) lost communication com con sys
U2172 (current, history) raidio
P0532 A/C Refrigererant pressure sensor A circuit low (pending,cur,old,history)
U0121 lost communication abs module
U2108 (current,old,history) CAN bus Erros ABS
looking for input/direction
thank you!
thank you!
