SmsDetroit
I’m getting ready to install a new pcm I got from ZZP with a tune (my pcm was tuner locked). When I pulled off the map sensors that came on the donor originally they were the Bosch 3 bar maps but the car didn’t run right. Whenever you got out of the throttle it surged through the turbo. So I put the stock ones back on and it ran fine. I thought the original pcm wasn’t tuned for it. Now that I’m getting ready to reuse them I noticed they are the same part number. Is that correct? The have the harness adapters for both that plug right in
