BSinvestments
Well, the motor is out to swap the clutch and transmission and I've fallen into a bunch of while I'm here questions. Cams, valve springs, deletes, but mainly I know it's recommended to swap the oil pan for an LDK pan to help with slosh. But does anyone know if the CBM sheet metal pan fits on a factory subframe, I unfortunately didn't measure with my motor in the car and they aren't sure if it works due to them mainly using it on one-off sand rails. I spoke to them today, it's built to order and I dont want to wait to put this thing back together and then it doesn't fit for some reason.
CBM MOTORSPORTS 2.0L/2.2L/2.4L ECOTEC FABRICATED ALUMINUM OIL PAN
CBM Motorsports Ecotec oil pans start with a 1/2" 6061 T-6 billet rail and are CNC machined to very tight tolerances. The pans are then formed from .90 3003 H-14 aluminum. This combination provides you with a light weight and very durable oil pan that will remain flat even after repeated...
store.custombuiltmotors.com
