Vwsaabvt
It should go in easy. Do you have new hoses or did you use your donor hoses? You can check to see if it is hose or caliper by opening the bleeder and seeing if it compresses easier. If it does, your brake hose is bad, if it is still hard with the bleeder open hte caliper is bad.One more quick question. How hard should you have to push a caliper piston to get it to move?
I am having to use some pretty healthy taps with a 2lb hammer to move it in the caliper.
I am having the front passenger brake stick hard. I can pull the caliper off and use a clamp to retract the piston but as soon as the pedal is pressed it stays clamped to the rotor.
It is only with that wheel, the rest work fine.
I did powder coat the calipers and don't know if I messed something up doing that.
