Yeah, that's right. But I want to make it as easy as possible for the engine and get prepared for making more HP. The heat exchanger currently gets only hand warm. Nothing to crazy. I think I measured around 100F.Just run it, you aren't going to hurt the engine. A good number of SC Cobalts are running without a working coolant pump in the intercooler system, and the PCM protects the engine by reducing the power. After a hard run in the goblin, touch the heat exchanger and see if it is getting hot. I can only get mine warm, and that is at race track. If you are running a turbo or a 2.6" pulley on your SC, you may find that the intercooler needs help, but the stock SC isn't that big of a heat generator.
Not sure about what part?@Gtstorey not quite sure what you mean. But I made some runs and monitored the IAT, IAT 2 and set up a user parameter IAT2/IAT.
Not sure about this part. What condition or start up do you mean? Engine start up after engine off. Start up after sitting at a red light,… >How quickly does your iat come back down after you start up again?
No. You just typically want to stay out of boost until it comes back down to “normal”My intercooler pump and the fans are currently run by a simple switch, that allows me to run it even if the engine is off and pull out heat from the system.
But, I can test it and switch it off with the engine. Do you have any guidance what temperature drop is good or bad and in what time frame?
Even faster is nitrous oxide across the heat exchanger or intercooler.A trick to increase radiator/heat exchanger efficiency is a water mist sprayed onto the coils/tubes. Liquid is able to pull heat quicker from a metal surface than air. Plus the water has an evaporative effect that creates more cooling and can even pull temperature lower than ambient when the air very dry (like out here in the deser).
