jaredthenav
Is there a template somewhere for the NACA duct kit, to cut the holes in the side of the hood? Had anyone come up with one? Trying to avoid a lot of trial and error when cutting fiberglass...
How did you get your vertical alignment?I used painters tape over the whole area, then traced the outline of the duct itself, then spaced in a set amount (can't recall how far) to give room for the overlap/rivets. I have the duct edge on the outside which hides any imperfections in the cut. I tended to cut too little out and then dremelled the opening up to fit.
Some like the duct edge on the inside instead which changes the cutout size.
Perfect, thanks!Trace your duct on some paper. Offset it in about 3/4" and draw another line. Cut on lines leaving a "ring".
View attachment 18490View attachment 18491View attachment 18492View attachment 18493View attachment 18494
I put the duct extra far into the pipe from the heat exchanger, installed the hood, slid the ducts out to touch the hood and traced the outline on the inside of the hood.How did you get your vertical alignment?
