neodied
Specifically regarding the clutch, I assume I need a new one based on:
- engagement point seemed to be about halfway through the travel
- dumping the clutch on a couple 2-3 shifts didn't result in the jerk I was expecting
- RPMs did not change quickly, it was much more of a smooth RPM decline when on throttle after a shift
So assuming I need a new one, my first thought is aluminum flywheel plus one of these options from ZZP:
- LSJ OEM Upgrade Clutch (https://zzperformance.com/collections/transmission-drivetrain/products/lsj-clutch-upgrade-kit)
--- Least torque holding capacity according to ZZP, but also the cheapest and not super stiff according to some people here
- South Bend Stage 3 350ft-lb (zzperformance.com/collections/transmission-drivetrain/products/south-bend-stage-clutches)
--- I don't think I'll ever hit the 350ft-lb ceiling on this, but it is more expensive and there are some reviews saying they had throwout bearing issues
- Clutch Masters Stage 3 470ft-lb (zzperformance.com/collections/transmission-drivetrain/products/clutch-masters-stage-clutches)
--- Way overkill torque rating, might be too stiff, also pretty expensive
Overall I'm leaning toward the OEM LSJ Upgrade one, placing a high priority on drivability.
Replacing the clutch will probably lead to more throttle bounce issues, so saving this thread for the future:
