PyroGuy923
Recently the car started to stall when running and occassionally wouldn't start. After doing some digging there was an igition switch recal on the Cobalts. I order a new switch with the intention to swap it out and learn the new key but boy was I wrong. I swapped the ignition switch and the car won't crank even after going through the relearn process multiple times (On 10 minutes, off 30 seconds, repeat 3 times). There is no security lock on the gauge cluster which is odd.
Thoughts? Checked numerous fuses at the BCM and engine fust panel. Fuel gauge isn't registering, no oil life, coolant temp showing -40 F.
