Friedhouse
Donor: 2007 Chevy Cobalt SS LSJ 3.0 pulley.
Finally just finished up the car, I have taken it out for small drives and pulls throughout the last 10% of the build, but nothing long. I went out today for a longer drive down the highway and started getting some misfiring. I immediately pulled over, turned around and started back home. Stayed in a low gear and limped back to my garage. Lean engine code p0171 was popped. After the car sat overnight, the engine will only crank over, but not run or idle.
If its a pump what do you all think is my best fix? Just a new stock pump, a ZZP or AEM fuel pump?
Are there any other diagnostics I can do to help me figure out what might be bad?
I was pretty **** depressed to take it out on my first full drive just to cut it short....
- I pulled the plugs and compression checked w/ all cylinders @180.
- Checked the fuel pump relay in the fuse box and they were good.
- Turning the car to acc I could hear the fuel pump start up to prime/run.
- Went and bought a fuel pressure test kit, installed it on the fuel rail, turned acc on and the fuel rail only reads 10psi for a few seconds, then drops to 0.
