DanPerryy
Lonny and Adam had a couple of steering column ignition switches without keys. You can buy uncut keys from multiple places. The car can be programmed to accept the code in a key - but what about getting the key to mechanically turn the ignition?
There are 3 different types of cylinders. The one shown in the pictures is called the "first design".
In looking through the service manual there is a description of how to remove the tumbler from the lock. The tumbler has a code on it that I imagine to be the mechanical key code.
To remove the tumbler I put a blank key in the switch and turned the key to run (up against the start spring). Then I put a pick into the hole in the switch casing nearest the key and pressed it down. There is a spring pawl on the tumbler itself that you are pressing down. The tumbler then pops right out.
After reading the instructions on how to key a cylinder the new cylinder is keyed with a final step of crimping some clips - essentially having to buy a new cylinder.
If you would just like to get your car running with a lost key you can grind off the little bar on the side of the tumbler cylinder essentially making any key work mechanically (even a screwdriver). The car will not start unless you program the key.
Sorry Lonny and Adam, you now have a universal steering column lock!!!
