MisterDave
I recently move from Rhode Island to North Carolina. It’s been two years and I’m finally getting the time to enjoy the goblin again. When I arrived it started and ran perfectly. I started it every now and then but didn’t drive it…Yesterday I had some time to check it over and it won’t start.
dash lights up like normal.
fuel pump does not start and fuel gauge doesn’t move at all. There is gas in it.
when I turn the key to start nothing happens. Doesn’t even try to start.
one random time the fuel pump engaged and it started right up but only ran for 5 seconds and then stopped.
Battery is 12.7 and was on a tender.
Even tried a jump box just in case
Cleaned ground contacts that connect to the frame under the fuse box.
I don’t see anything out of place.
Should I replace the fuel pump fuse?
What else should I check?
Wouldn’t the starter try to start even if the fuel pump didn’t engage?
