CaptFrank2001
I did not save anything from the donor & I am considering adding a parking brake (car is finished). Is the Parking Brake Kit complete or will I need to run down some additional parts? Thanks
In addition to what DF supplies when you order the parking brake kit you will need the ebrake handle with the short cable to splitter that the cables hook to. You will also need the aluminum e-brake tubes. I think thats all you need from the donor.I did not save anything from the donor & I am considering adding a parking brake (car is finished). Is the Parking Brake Kit complete or will I need to run down some additional parts? Thanks
I did not have the stock tubes for mine, but I had good success using coiled copper water line. It forms easy enough and holds its shape well.Looks like I have all the parts except the aluminum tubes. May need to visit a salvage yard.
Probably looks cool tooI did not have the stock tubes for mine, but I had good success using coiled copper water line. It forms easy enough and holds its shape well.
Probably will try that. ThanksI did not have the stock tubes for mine, but I had good success using coiled copper water line. It forms easy enough and holds its shape well.
