LOL![snipped][/snipped]
Also, If it makes you feel better I had the engine totally in and close to starting when I remembered to put the clutch line in. Boy that was fun.
Nuker-
That sounds like my first day as a part time John Deere mechanic (1974) working on a brand new lawn tractor. The compression release on the crankshaft was adjusted too far (i.e. broke off) and I was given a BFN crankshaft, pointed to the new lawn tractor and then pointed to the factory service manuals and told, go for it. My motorcycle drag race friend was the service manager...
No problem EXCEPT for reassembly and putting on the muffler before I needed to. I ended up putting it on, taking if off, assembling some more pieces on the motor, putting the muffler back on, finding more that had to go on the motor before the muffler, taking the muffler back off, etc.
Somehow I needed to have that muffler ON THAT TRACTOR!!! Even though I had the muffler on and off three times before it stayed on, I was only 30 longer than flat rate for that engine teardown and rebuild.
I try to follow instructions better after that. And that is why I didn't think of the clutch line since it wasn't mentioned in the AUTO Goblin build.
I did go back out to the shop and install the line after my above post. First thought was, which way does it need to go? I believe I have it in the frame correctly since the other way has bends that doesn't come close to the slave cylinder location.
