I have an '06 SS with the LSJ donor. Every other light on my goblin is working well except my reverse lights. I test the lights themselves to make sure they are wired correctly. I have looked through every fuse I can think of. I replaced the reverse light switch on the transmission. I manually pressed the switch to make sure it was not the transmission. I then tested continuity from the reverse light switch plug to the lights themselves and found there is no continuity. If anyone knows why this is, and where I should look next, or have any other ideas of the issue, that would be greatly appreciated. Thank you.
