Tell Chris (I'm sure you got his number) to post a little bit about his Goblin. Sharp color combination, very clean looking with the white and red - and the chrome wheels.
I have seen this car for sale on the Goblin owners Facebook page a few times. I am glad your willingness to let a complete stranger get into your car is motivating him to finish!Sunday morning I went to the local cars and coffee, and on the way home I drove thru old downtown Rogers, Arkansas.
Someone at a cross walk held out their hand, so I stopped to see what they wanted.
He said he owns one of these (goblin's) but he hasn't finished it, so he hasn't had a ride in one.
I said, hop in, I'll take you around the block.
So it turns out Chris is from Texas, and he built this car:
I've never picked someone up off a cross walk before,
but his wife phoned on the way back, saying his food was ready.
He had ordered food from a restaurant patio, then hopped in my car, and left his family!
It was good to catch a quick visit with a fellow goblin builder.
He said the ride was awesome, and gave him motivation to finish his project.
Yeah, I saw your post. I reads just so scary what you had to do to get the plug out. I thought it might be easier at the oil cooler.The LSJ block has a spot for an oil pressure sensor. It is blocked off, and the LSJ uses an oil pressure switch to turn on an oil light if the pressure drops below a preset ~20 PSI. The oil pressure switch is over by the stock oil cooler.
You could hook up an oil pressure sensor lots of places, including modifying the oil pressure switch for an oil pressure sensor.
Well, amazing idea! That's what I will try to do. I'll have look if there is enough space.Why over complicate it, put a tee in the block port and mount both the stock pressure switch and the pressure sensor. Easy peasy.Unless you are hard set on creating a circuit to correlate the switch signal into pressure and get it reading the correct ft.lb. value. If you are successful just be ready to make a bunch to sell.
Might be best running a hose and putting the sensors elsewhere. Will follow up on my build log when I get a chance. Currently in Thanksgiving travel.Be careful with what you use for tees. Small normal brass pipe tees and nipples may not support the weight of multiple sensors with the vibration they are subject to.
I hear you....and I am running out of excuses of doing anything else but using the spot on the block. But I will continue whining on my build log.Run a hose off a brass T just to run a oil pressure sensor? Well that would work, but what was wrong with just removing the stock plug in the side of the block, that was designed to hold an oil pressure sensor? I know I had a hard time, but Lonny set me straight, and with a propane torch for heat, it came out easy. There is oil pressure sensors that use the stock thread pattern, rather than using the adapter that I found for a generic pressure sensor.
I made a manifold header that I bolted to the side of the block and attached with a hose.Might be best running a hose and putting the sensors elsewhere. Will follow up on my build log when I get a chance. Currently in Thanksgiving travel.
