Seat brackets
Just got my seats in after 2 months back order. Looking to buy mounting brackets and adjustable sliders. I want to be able to teach my kids to drive a manual.
We used the sliders out of the donor and custom made and adapter plate to work with the seat. That doesn't help you much, but trying to give a response.
jamesm
I have the Planted Tech brackets. They fit fairly well aside from the notch on the front. It needs a spacer as the notch is larger than the square tubing on the chassis.
My only complaint with them is once you add the sliders, the seats sit higher than I’d like.
SmsDetroit
I added 2 bolts (going to add 2 more) threaded from the bottom up. It takes up the gap on the planted tech brackets. It made it adjustable.
jamesm
I saw that. That's an awesome solution. I'm definitely stealing that idea.
TheDon
I still need to pick out some brackets 65 a pair for the cheap stuff or 160 each for the planted tech, seems both need modifications?
