Had some ups and downs this weekend. The weather was awesome on Saturday and I was able to get the tail lights wired up and working the way I wanted. I ran another set of wires from the front turn signals and used the 3rd brake light circuit so I could separate the functions as opposed to using the stock combined wire.
I had some trouble with the brake sensor. I broke the screw off in the donor sensor and couldn't get it out, so I bought a new one. I guess the new one needs to be calibrated or something, the brakes came on and stayed on when it was installed. I swapped out the new one for the old one and just zipped tied it on, will deal with the new sensor some other time.
The weather today was awful, 102°F and 70% humidity, but I managed to get the rest of the coolant lines installed and fired it up for the first time. Only had 3 DTCs, all of which were related to the evap system. I let it warm up and I think I got all of the air out of the coolant loop.
It seems like all of the buttons on the gauge cluster work so far, but I haven't tested the cruise control yet.
Moved onto the shifter, got to this point without too much issue
Last week I noticed I was missing the shifter cable bracket that mounts to the transmission. I contacted DF customer service, they promptly responded and mailed me one. It arrived yesterday afternoon. I panted it this morning, and then found out it didn't fit when I went to install it. Shame on me for not test fitting before painting I guess
The plate runs into a boss on the transmission. I'm not sure if I got the wrong part or if I'm just supposed to start grinding, but It was too hot and too late for me to get the grinder out this afternoon, so that will be a problem for next weekend.
I also decided to put my heat exchanger in the rear ala
@Rauq
I think the kit was supposed to come with a plug for the "filler" tee, but I didn't have one in my kit. I picked up a 3/4" pex plug but it's a pretty loose fit. I may end up ordering one of
these instead.
I also found out yesterday that my kit was missing some front brake line clamps. I ordered
these to take care of that.
Getting close. After next weekend I may try to schedule my Troop C inspection.
