Goblinfanclub1234
I made up this prototype throttle pedal spring bracket to help with starting in 1st gear.
1) bracket designed to fit in throttle pedal bolt holes, I used some left over 6061 aluminum I had. it sandwhiches between the pedal assembly and the mount.
2) Spectre throttle springs I found at autozone
3) drilled the 1.25 inch hole and held it up to the throttle to mark the bolt holes
4) eyeballed where the spring sits nice and drilled holes
This thing makes a very noticable difference in driveability. I may still exeriement with stronger springs. It will move the pedal towards the tunnel by the thickness of the bracket, allowing my foot to rest easier on the tunnel.
I thought about possibly selling this as a kit on here but its not that hard to make.
UNITS ARE IN INCHES
UNITS ARE IN INCHES
