GoblinGuyZ
Wondering what you guys are getting as max psi in 2nd gear from stock LSJ. Mine is 2006. I'm seeing 9-10 psi max from mine and wondering if that's normal. Just usual DF Intake and a custom exhaust. Engine has healthy compression 215 or so across all cylinders and vacuum seems fine.
I am getting code P0033 Turbo Bypass Valve which would make sense if I have an issue with this.
The vehicle was built when I purchased it but I noticed two unused harness connectors in the area of the bypass valve and wondering if I'm missing anything needed for the bypass to function correctly. TIA
