After Towerdog and Waterdriver's comments I felt I needed to get educated on transmission mounts as I am uninformed on them.
Found this article
Engine Mounts 101: A Basic Guide to Choosing Engine Mounts. The Cliff Notes version is there are 3 types of motor mounts, rubber (normally OEM), polyurethane and finally solid.
Basically starting with rubber, less vibration/noise but less power to the wheels up to solid which is more vibration but also most power to the wheels.
The article does not recommend mixing the types of mounts in use, as it could cause flexing like Waterdriver mentioned.
Then in the forum, Adam posted on 10/31/2017 about
Solid Transmission Mounts which Waterdriver also called out. In the messages, ctuinstra also states that mixing mounts is not a good idea. Christopher Sanchez also says that it is used to get rid of wheel hop which Towerdog asked.
But found in the thread
Save Motor Mounts the discussion again touches on solid and not mixing mount types but it appears there are no solid transmission mounts for a NA motor as it does not produce enough power to warrant solid mounts.
So at this point, it appears stock mounts will work on our build at is it a NA up until the time we add more power to it sometime in the future.
Thank you guys for the information! Learned something new tonight and that is always a great thing.
