Sub frame mount
ole mother
Can someone tell me why, the kit comes with carriage bolts? Neither side of the sub-frame has a spot for the head of the bolt to fit into. What am I missing?
I ground the square to a round and put a flat on each side for a wrench to get it flush w the subframe.
How much torque were you able to achieve? If I recall the subframe bolts require quite a bit to ensure no movement of the subframe against the tube frame mounts.
