I guess I’ll skip over it then. I plan on leaving the factory power outlet and mounting it in there somewhereYou don't "need" the fog lamp circuit. It's only used as an accessory circuit if you want to use it. There are some quirks with its operation, so it has limited use case anyway. I will be using mine to run aftermarket seat heaters.
In my many years at Chevrolet they rarely have optional equipment wired, sometimes yes but most times noInteresting thing is that for most GM wiring harnesses they were all made the same. Even though your donor may not have had fog lights the wires for them (and sometimes the connectors too) are in the harness, usually pulled back and taped off on the assy line.
Did I mention I have/sell those red + post covers?, I collected them at the junk yards.In my many years at Chevrolet they rarely have optional equipment wired, sometimes yes but most times no
OMG! There IS a Mustang hiding in that photo!! Did you say Fastback???? Let's mid-engine it! AWWW! Come on!, it'll be fun!(I once said childishly.) No back seat?, but you really didn't want the WHOLE family along anyhow! A SBF and a trans out of a Audi FWD model or a Boxter?, they made automatics! IRS rear suspension out of a late Mustang? OOH! Is there a FWD Ford car with a suitable transverse engine/trans/suspension donor? I Know! SHO Taurus? OR Maybe something from Ford Germany? German Ford stuff is hot/crazy! Did you ever see the Merkur SVO XR4Ti? (I don't think the Ford Germans answer their phones if caller ID shows it's Detroit calling!)Looks like my harness is ready for the wife’s Goblin minus where I ran short of tape on the headlight wiring
My research so far is in 05-07. On these Cobalts, I think that depends upon which sub-system wiring harness you are looking at. The front light harnesses usually did not have the fog light wires, but the body harness(I believe and will recheck mine) did as part of the headlight wiring. (I'll have to dig deeper on this point as I would like to know for sure if ANY of the wiring harness are universal to all Cobalts.) I have a couple of fuse panels along, I think they all have a fog light fuse position, will need to see if all are wired for fog.
All body harness and dash harnesses I have worked on, the connector for both neutral safety start switches(Manual on the clutch pedal and auto on the shifter) the unused plug is in the harnesses, but taped out of the way.
Engine harnesses are manual or auto or SS/SC. SS/SC use a different ECM plug on the body harness. Sadly the steering/brake panel bolted into the body is auto or manual with the hole for the master and clutch pedal bolts.
Side Story: The transmission wiring can be cut out of the Automatic engine harness with little trouble, the Speed sensor is shortened and needs a new plug end(a copy is in the headlight harness, IIRC "temp probe" Maybe?) and some other changes, but the Auto transmission portion of the engine harness almost could have been a separate sub-harness.(Built together for quick factory assembly and slow, aggravating service.)
[/QUOTE
Believe it or not I actually do have a red post cap
No sir, this one I’ve had forever and is a factory 390 gt 4 speed carRed + cap intact? Figures!, Just when I have 20 in stock! Hey! What about that MR2/ Mustang plan? You could be the guy!
OH! in that case never mind! That'll make ya Steve McQueen!No sir, this one I’ve had forever and is a factory 390 gt 4 speed car
