Tire Decision
Me to. Not sure how exact tire to wheel recommendation are for such a low weight/air pressure situation.
I was thinking about that. On the rear, probably not a major concern. On the front, there may not be enough weight to let the tire make decent contact, with the wheel bowing the tire
SmsDetroit
8.5 seems to be min width.
I picked up a set of 17X8” wheels for cheep. Was going to use them for trailer tires when flat towing. However when talking to my tire guy he said you could put a 255 on them as long as you went with a 45 series and up sidewall. I’ve seen a lot of talk about width but not much on sidewalls. I’d be going from 275/40R18 rear and 255/40R18 front down to a 17” wheel. I’d like to run a 245 /40 up front and a 255/40 out back. Is a 255/45 to tall of a sidewall for Autocross? This might change what I do. I’d go to a 100tw tire on the 17” and keep my 18” for street driving and towing. Thoughts?
I’m hoping to improve traction for Autocross. I’ve read that a narrower tire would heat up quicker which helps with Autocross
I ended up getting a set of 225's for my 8" wheels. Then I got my hands on some 9" wheels and got the 255's on those. The 255 look like they fit perfectly on the 9" wheels.
