Is there a such thing with the Goblin being RWD and torque steer really only affecting FWD? The reason I ask is that a full throttle pull from a slow speed to 70-80 MPH can be a scary experience. It doesn't want to go in a straight line. It wants to wobble left/right. I don't know if it's because of my alignment settings, torque steer, weight transfer, bumps in the road, or a combination of all that.
Brad mentioned that it can be caused by worn out control arm bushings. One of the control arms is brand new and the other one doesn't appear to have any obvious issues. The donor only had 47k miles on it.
My alignment settings are pretty much set to what DF recommends. The only thing that is slightly off is the caster which is set to about 7 degrees instead of the recommended 8 degrees. I'm not sure how that would even affect how it drives.
