Davidljones88
My k04 turbo is getting replaced with a z54. The turbo is too big for the stock gasket. I need an extra 1/4" of space so it can mount up. Any ideas where to buy one?
The Z54 outlet has a V band flange on it, did you just cut it off or grind it down to be able to get that straight fitting on?View attachment 36389Here is a pic of mine. Heat shields need to be removed and are not used. As r3drckt said the compressor side of the turbo just barely clears the manifold without shields.
