aaronbuley
Any suggestions on how to remove this plug?
Not coming off easy and don’t want to break it. Just pull harder??
thanks!Aaron, please look at my post for the ABS Plug Wire Removal in the Electrical section. The plug has a couple sliding tabs that retain it on the ABS module.
Did you have any luck with getting the ABS module connector removed?thanks!
Wire cutters. HeheDid you have any luck with getting the ABS module connector removed?
