Welder purchase
Jareth
Men should have a welder, I don’t :(
I have never welded any thing befor, ok so maybe be once when I was careless installing a car battery once.
Would this be ok for my minimal welding needs that I may want to do, some diamond plate floorboards, seat supports, and maybe some mounting tabs for a few things?
r3drckt
Should do just fine. I got the Titanium Easy Flux from HF during a sale around Christmas for $170. Between the 2, I liked the adjustability of wire feed settings and voltage for the Titanium that the Chicago Electric didn’t have. The Titanium also had a nice cheat sheet for settings based on the metal thickness you’re welding. Right under the lid where the wire is. Pretty convenience for us novice welders.
Brett
I've heard those base model Harbor Freight models are hit and miss.
I have a Hobart Handler 140 for the past 10 years and it will do what you have listed.
Harbor Freight now has some higher end welders that are supposedly much better but I have no experience with them.
I only fire up the Hobart about once every six weeks so take my input for what its worth ;-)
As long as your diamond plate is steel, it will work.
Aluminum welding is different. I bought a TIG welder so I could weld multiple metals, but still prefer MIG for steel and speed.
That will get you started in welding. Where it takes you, is up to you.
Towerdog
I would agree with Brett and go w a Hobart. Alot of the HF welders are flux core wire only and that stuff is a disaster to weld with. I've had a Hobart for over 30 years with no problems. Plus they hold their value better.
Jareth, if you need an inexpensive beginners welder to learn how to weld, the basic HF (Chicago) will get you there. I had one of those for 20 years to do small projects and it worked just fine. If after you get some skills at welding, with better understanding of wire feed speed and heat, although the Chicago has only Min and Max, you can always get a more expensive welder with more features. It all depends upon how many $$$ you want to spend versus the amount and type of usage will need it for. :)
CodyP
Keep in mind that the Harbor Freight flux welders are made for simple repairs and never were intended for large projects. From what I've read and can remember, the problem is that the polarity is reversed because they lack certain parts(capacitors, inverter, larger ground/leads, etc). That being said, even though they splatter and make more of a messy weld than other branded machines using the same wire, with practice and a couple of upgrades they can be decent. You can Google upgrades for them. If you want an easy setup and good looking welds from the start and have a little higher budget, go with a Hobart or Lincoln mig welder. MIG incorporates a shield gas around the weld and keeps the spatter down. If you don't want to mess with gas and still want a low end machine, the Hobart and Lincoln flux core welders still make cleaner/easier welds than the Harbor Freight one. Save yourself a headache and spend a little more upfront for the Hobart. Then buy the accessories from HF like helmet, gloves, chipping hammer, wire brush, clamps, magnets, wire, gas, and you'll save money. Hope that helps.
Jareth
Thanks guys, for my first welder I think I’ll need to get an inexpensive one.
And during some research today I found another option to consider instead of diamond plate?
You may be able to find a used welder on Facebook or Craigslist that somebody bought from HF.
Or a good deal on a used big machine. One of the Hobart's we use was a used machine and works great and was only a few hundred bucks.
Goblin Graber
Nothing wrong with a HF welder...just don’t get that one. Step up to a Titanium or a Vulcan with shielding gas. I have an Omnipro 220 and it’s nicer than any other MIG welder I’ve owned. Just dial in a material thickness abs go to town.
Towerdog
If you order them as rear mats they would only be $80.
ccannx
If you buy a cheap welder and learn how to weld with it you will be a pro when you decide to get a nice one... This Hobart is under 250$ and it will be easy to sell later if you want a bigger one. Plus you wont feel like you wasted 200 dollars on a piece of junk like I did off Amazon. Hobart
Jareth
I agree, it will unfortunately be months until I need one so I will keep my eyes out for a used one on CL & Facebook Marketplace.
