starxu was a dirty spammer trying to sell his own wheel spacers. So instead of sharing his link, how about we share a link to a competitor: https://motorsport-tech.com/
I'd take it one step further than the Sasqwatch and say hub centric AND wheel centric spacers are the ones to use. They're a decent amount more than standard spacers, but ensuring the spacer is hubcentric to the hub, and then also has a wheel centric flange on the wheel face of the spacer ensures that everything is perfectly centered. Having the spacer hub centric is pointless if the wheel still isn't centered correctly.
Motorsport Tech is your absolute number one source for wheel adapters, wheel spacers, and hub centric rings. We manufacture the finest adapters in the world, and we do wheel polishing, chroming, powder coating, and color matching, as well as sell wheels and tires at WHOLESALE PRICES.
That's who I ordered mine from as well. They're good quality and worth the money. test fit on the hub and it's dead center with no play. Same thing with the wheel side as well. My only gripe with them is the ends of the studs they provide are flat and threaded all the way. Because of this, the lug nuts I have won't seat all the way down. I grabbed this to chamfer the bolt ends. May need to still trim the ends a bit, but we'll see. I think the chamfer will solve the issue.
I have the 5x114 hubs and went with these. The hub on my new rims is 73mm. Only used the spacers in the front as I needed a few mm to clear the brakes.
