When did you all say "good enough" on your VE tables while tuning? I'm using HP tuners, of course.
I've been tuning the VE table for quite a while (40+ runs). I think I have it mostly dialed in, and it runs pretty well. However, some of the cells still "spike" every once in a while. I generally try to smooth those out. If I don't smooth them, and just do run after run, I end up with all sorts of spikes everywhere, and the map is just a mess.
In general, most of my cells are +/- 5%. Some are +/- 10%. Every once in a while, I'll get an anomaly that goes +/- 20%, then I drive it again, and it moves, or disappears entirely. I'm worried I'm chasing sensor noise at this point, that may or may not be real issues.
Do you think the long term trims will handle it from here? Or does it need to be much better before letting the ECU do its thing?
